Antique radio programming-on KBRD radio
FYI: If you like listening to the music that was being produced when our favorite Philcos were being made, you might want to check this link out. Several people are now using small AM transmitters hooked up to their computers to play this music on their home radios.
http://www.hezzie.com/kbrd/
Antique radio programming-on KBRD radio - by theblurrrr - 05-18-2008, 10:47 PM
[No subject] - by Ron Ramirez - 05-19-2008, 06:42 PM
[No subject] - by Uffda - 05-19-2008, 09:27 PM
Philco 91 Tuning Condenser
There are currently 3797 online users. [Complete List]
» 2 Member(s) | 3795 Guest(s)
