Just received a 650B.....pics
Here's a vid of it in operation.
http://www.youtube.com/watch?v=MOM9Y-3jOj8
-Brian
If you collect or are interested in antique telephones, please visit Classic Rotary Phones
http://www.classicrotaryphones.com/forum/index.php
Just received a 650B.....pics - by BDM - 05-17-2008, 12:52 PM
[No subject] - by signaltracer - 05-17-2008, 08:33 PM
[No subject] - by BDM - 05-17-2008, 09:36 PM
[No subject] - by BDM - 05-18-2008, 09:31 PM
[No subject] - by signaltracer - 05-18-2008, 09:52 PM
[No subject] - by BDM - 05-18-2008, 10:13 PM
[No subject] - by exray - 05-18-2008, 10:17 PM
[No subject] - by BDM - 05-18-2008, 10:24 PM
[No subject] - by BDM - 05-19-2008, 12:41 AM
[No subject] - by signaltracer - 05-19-2008, 12:02 PM
[No subject] - by Ron Ramirez - 05-19-2008, 06:42 PM
[No subject] - by BDM - 05-19-2008, 08:19 PM
[No subject] - by BDM - 05-20-2008, 10:12 PM
Philco 91 Tuning Condenser
