40-201 now has power
Today I continued some work on the chassis by replacing items 16 and 15, 47K ohm resistors, and item 37 a 33K ohm resistor. In the process I found an added resistor, a 27 ohm between the grid of the 7J7 Mixer/Oscillator tube and the band switch which is not on the parts list or the under-chassis parts illustration. This is likely a modification to reduce the possibility of spurious high frequency oscillation. Neither the Ryder information nor the Philco Service Bulletin 321 show that added resistor. I need to do some further checking to see if I can find information on this. It would be interesting to see if my suspicions are correct.
I hope to get the remaining capacitors I ordered so I can finish up the chassis work.
40-201 now has power - by Joeztech - 12-23-2013, 03:45 PM
RE: 40-201 now has power - by jerryhawthorne - 12-23-2013, 04:27 PM
RE: 40-201 now has power - by Joeztech - 12-23-2013, 06:45 PM
RE: 40-201 now has power - by jerryhawthorne - 12-23-2013, 07:13 PM
RE: 40-201 now has power - by Joeztech - 12-23-2013, 08:08 PM
RE: 40-201 now has power - by codefox1 - 12-23-2013, 08:56 PM
RE: 40-201 now has power - by jontz - 12-23-2013, 09:33 PM
RE: 40-201 now has power - by Paul Philco322 - 12-23-2013, 11:11 PM
RE: 40-201 now has power - by Joeztech - 12-24-2013, 07:33 AM
RE: 40-201 now has power - by Joeztech - 12-24-2013, 07:45 AM
RE: 40-201 now has power - by hsusmann - 12-24-2013, 10:14 AM
RE: 40-201 now has power - by Joeztech - 12-24-2013, 04:53 PM
RE: 40-201 now has power - by hsusmann - 12-24-2013, 05:53 PM
RE: 40-201 now has power - by Joeztech - 12-24-2013, 08:03 PM
RE: 40-201 now has power - by hsusmann - 12-24-2013, 08:53 PM
RE: 40-201 now has power - by Joeztech - 12-24-2013, 10:54 PM
RE: 40-201 now has power - by Radioroslyn - 12-25-2013, 11:15 AM
RE: 40-201 now has power - by Joeztech - 12-25-2013, 03:34 PM
RE: 40-201 now has power - by BrendaAnnD - 12-25-2013, 06:47 PM
RE: 40-201 now has power - by Joeztech - 12-25-2013, 07:05 PM
RE: 40-201 now has power - by Joeztech - 12-26-2013, 08:15 AM
RE: 40-201 now has power - by hsusmann - 12-26-2013, 09:53 AM
RE: 40-201 now has power - by Joeztech - 12-26-2013, 11:48 AM
RE: 40-201 now has power - by hsusmann - 12-26-2013, 10:54 PM
RE: 40-201 now has power - by BrendaAnnD - 12-26-2013, 11:59 PM
RE: 40-201 now has power - by Eric Adams - 12-27-2013, 01:50 AM
RE: 40-201 now has power - by Joeztech - 12-27-2013, 07:28 AM
RE: 40-201 now has power - by Joeztech - 12-28-2013, 01:28 PM
RE: 40-201 now has power - by Joeztech - 12-28-2013, 05:36 PM
RE: 40-201 now has power - by codefox1 - 12-29-2013, 08:30 PM
RE: 40-201 now has power - by morzh - 12-29-2013, 08:42 PM
RE: 40-201 now has power - by Joeztech - 12-30-2013, 07:17 AM
RE: 40-201 now has power - by Joeztech - 12-30-2013, 07:30 AM
RE: 40-201 now has power - by Joeztech - 12-31-2013, 06:33 PM
RE: 40-201 now has power - by jerryhawthorne - 12-31-2013, 07:54 PM
RE: 40-201 now has power - by Joeztech - 02-19-2014, 08:05 PM
There are currently 9787 online users. [Complete List]
» 2 Member(s) | 9785 Guest(s)
