Just received a 650B.....pics
Looks and sounds great! I don't think I have *ever* gotten a set done "overnight!" I was never particularly partial to that shouldered cabinet style; however, after seeing and hearing your success, I may have to try to find one!
Regards,
Charlie
Just received a 650B.....pics - by BDM - 05-17-2008, 12:52 PM
[No subject] - by signaltracer - 05-17-2008, 08:33 PM
[No subject] - by BDM - 05-17-2008, 09:36 PM
[No subject] - by BDM - 05-18-2008, 09:31 PM
[No subject] - by signaltracer - 05-18-2008, 09:52 PM
[No subject] - by BDM - 05-18-2008, 10:13 PM
[No subject] - by exray - 05-18-2008, 10:17 PM
[No subject] - by BDM - 05-18-2008, 10:24 PM
[No subject] - by BDM - 05-19-2008, 12:41 AM
[No subject] - by signaltracer - 05-19-2008, 12:02 PM
[No subject] - by Ron Ramirez - 05-19-2008, 06:42 PM
[No subject] - by BDM - 05-19-2008, 08:19 PM
[No subject] - by BDM - 05-20-2008, 10:12 PM
Philco 91 Tuning Condenser
There are currently 6533 online users. [Complete List]
» 1 Member(s) | 6532 Guest(s)
