Hello need help with my 1951 730L
Welcome to the Phorum!
I'm thinking that is a capacitor, and it needs replacing. And all the other capacitors will need replacing as well.You will need to find a schematic for your set. I'm sure others will chime in here.
Gene
Hello need help with my 1951 730L - by carmentripster - 12-28-2013, 04:31 PM
RE: Hello need help with my 1951 730L - by Gene Pederson - 12-28-2013, 08:36 PM
Philco 91 Tuning Condenser
