Capacitor Value in Production Change
The Run Changes for the 40-195/200/201 show that on sets marked Run 8, a mmfd. condenser, Part No. 30-1097 is connected in parallel with compensator 26B.
Can someone identify the value of this capacitor for me? It is not stated in the note on the documentation I have.
Thanks in advance.
Joe
Capacitor Value in Production Change - by Joeztech - 12-29-2013, 09:42 AM
The speaker table error?
Philco 70 antenna lead
