Capacitor Value in Production Change
30-1097 is 5 pF silver mica.
I would not add it unless when you align the radio, the trimmer is almost all the way tight (max capacitance)
John
Las Vegas, NV USA
RE: Capacitor Value in Production Change - by LASJayhawk - 12-29-2013, 01:13 PM
The speaker table error?
Philco 70 antenna lead
