Atwater Kent model H speaker
I plugged it into my 1925 Liberty Five TRF. Five 01A tubes. With my Brandes Table Talker speaker it has good volume. When I attached the AK-H, it was very low. The 9v battery test yielded similar results between the two speakers.
Atwater Kent model H speaker - by Groundhog74 - 12-28-2013, 10:41 PM
RE: Atwater Kent model H speaker - by Mondial - 12-29-2013, 01:13 PM
RE: Atwater Kent model H speaker - by Groundhog74 - 12-29-2013, 02:48 PM
RE: Atwater Kent model H speaker - by Groundhog74 - 01-02-2014, 08:40 PM
RE: Atwater Kent model H speaker - by TA Forbes - 01-03-2014, 12:08 AM
