Pulled out my 37-650 tonight
Final post for tonight:
I just did some searching and it looks like my
cabinet has been stained or painted or something
all one dark brown color!
I had no idea what they are supposed to look like
but after seeing some pictures on this Phorum
and also other places online I see that mine
has been worked over before.
I will have to see if I want to try to restore
this cabinet or not.
Maybe I'll just get the chassis working and
put it in the cabinet and call it "done".
Herb S.
Pulled out my 37-650 tonight - by hsusmann - 12-26-2013, 12:35 AM
RE: Pulled out my 37-650 tonight - by morzh - 12-26-2013, 11:17 AM
RE: Pulled out my 37-650 tonight - by AI2V - 12-26-2013, 12:14 PM
RE: Pulled out my 37-650 tonight - by hsusmann - 12-26-2013, 10:46 PM
RE: Pulled out my 37-650 tonight - by hsusmann - 12-29-2013, 09:44 PM
RE: Pulled out my 37-650 tonight - by hsusmann - 12-29-2013, 09:55 PM
RE: Pulled out my 37-650 tonight - by morzh - 12-29-2013, 10:00 PM
RE: Pulled out my 37-650 tonight - by hsusmann - 12-29-2013, 10:00 PM
RE: Pulled out my 37-650 tonight - by hsusmann - 12-29-2013, 10:04 PM
RE: Pulled out my 37-650 tonight - by morzh - 12-29-2013, 10:12 PM
RE: Pulled out my 37-650 tonight - by hsusmann - 12-29-2013, 10:13 PM
RE: Pulled out my 37-650 tonight - by morzh - 12-29-2013, 10:18 PM
RE: Pulled out my 37-650 tonight - by hsusmann - 12-29-2013, 10:22 PM
RE: Pulled out my 37-650 tonight - by morzh - 12-29-2013, 10:30 PM
RE: Pulled out my 37-650 tonight - by hsusmann - 12-29-2013, 11:37 PM
RE: Pulled out my 37-650 tonight - by Ron Ramirez - 12-30-2013, 01:06 PM
RE: Pulled out my 37-650 tonight - by Joe Rossi - 12-30-2013, 10:01 PM
RE: Pulled out my 37-650 tonight - by hsusmann - 12-31-2013, 12:40 AM
RE: Pulled out my 37-650 tonight - by BrendaAnnD - 12-31-2013, 02:24 AM
RE: Pulled out my 37-650 tonight - by hsusmann - 12-31-2013, 09:53 AM
RE: Pulled out my 37-650 tonight - by hsusmann - 01-05-2014, 02:42 PM
RE: Pulled out my 37-650 tonight - by hsusmann - 01-05-2014, 10:12 PM
RE: Pulled out my 37-650 tonight - by codefox1 - 01-05-2014, 11:28 PM
RE: Pulled out my 37-650 tonight - by hsusmann - 01-06-2014, 09:40 AM
RE: Pulled out my 37-650 tonight - by Eric T - 01-10-2014, 08:04 PM
RE: Pulled out my 37-650 tonight - by Jamie - 01-11-2014, 10:52 AM
RE: Pulled out my 37-650 tonight - by hsusmann - 01-11-2014, 11:57 AM
Philco 91 Tuning Condenser
