Bakelite cap #'s can't find.
Brett,
Looks like both were single .05 - 400V caps:
http://philcoradio.com/tech/images/bakelite.pdf
Carl
Northern Panhandle, WV
Bakelite cap #'s can't find. - by baspas - 12-30-2013, 12:45 AM
RE: Bakelite cap #'s can't find. - by Carl Travis - 12-30-2013, 01:23 AM
RE: Bakelite cap #'s can't find. - by baspas - 12-30-2013, 09:26 AM
There are currently 7153 online users. [Complete List]
» 1 Member(s) | 7152 Guest(s)
