RESISTOR ID 38-15 philco help
http://s1289.photobucket.com/user/TROG99...c.jpg.html
I have had some time to look at the 38_15. What I have found is #22 the 4 Meg is gone. A 7Meg to ground is on the cap side to Tube 75 that #22 the 4 Meg went to.
Further # 17 2Meg is gone. It looks like they split into two 1 Meg and attached a Cap in between.
Above picture is of the bottom side again. I went thru and I identified each component. I have a small idea of what they did. Just a lil foggy the 2 1 Meg connect. It was late so I have only tried to get a picture have changed nothing.
The 1 Meg attached to the TB reads 975K. It then attaches to the Switch #3 position A5-A7. This is where the switch is setting did not move it.
The other reads 1.1 Meg goes from Tube 75 pin 3 the junction point of the three components to pin 5.
The 7 Meg attaches to #21 Cap the side not attache to the 500k variable resistor #20 then goes to ground.
I am making a schematic to show were they attach. After looking at the 38-10 it does appear close to that configuration.
I have assumed that #3 is the A5-A7 because I did not see that on the electronic schematic just on the Bottom view.
I would like to make sure I'm not sitting near the bleachers in left field. I will at this point replace them one for one.
RESISTOR ID 38-15 philco help - by Bradley Rush - 12-13-2013, 04:50 AM
RE: RESISTOR ID 38-15 philco help - by vinzer - 12-13-2013, 12:49 PM
RE: RESISTOR ID 38-15 philco help - by Mondial - 12-13-2013, 04:16 PM
RE: RESISTOR ID 38-15 philco help - by morzh - 12-13-2013, 05:11 PM
RE: RESISTOR ID 38-15 philco help - by vinzer - 12-13-2013, 06:34 PM
RE: RESISTOR ID 38-15 philco help - by BrendaAnnD - 12-13-2013, 08:12 PM
RE: RESISTOR ID 38-15 philco help - by Mondial - 12-13-2013, 09:05 PM
RE: RESISTOR ID 38-15 philco help - by Mondial - 12-13-2013, 10:38 PM
RE: RESISTOR ID 38-15 philco help - by Bradley Rush - 12-30-2013, 03:07 AM
RE: RESISTOR ID 38-15 philco help - by David - 01-08-2014, 07:21 PM
Philco 91 Tuning Condenser
There are currently 10161 online users. [Complete List]
» 3 Member(s) | 10158 Guest(s)
