42-1008 SHORTWAVE BAND SILENT
Try using some tuner cleaner on the band switch contacts.
Often the shortwave band(s) were not used much so those
contacts never got much wiping action and are thus
dirty.
I did a radio recently that did the same thing, once
I cleaned the switch contacts all was fine.
Herb S.
42-1008 SHORTWAVE BAND SILENT - by davidff - 12-30-2013, 09:30 AM
RE: 42-1008 SHORTWAVE BAND SILENT - by morzh - 12-30-2013, 09:58 AM
RE: 42-1008 SHORTWAVE BAND SILENT - by hsusmann - 12-30-2013, 10:18 AM
RE: 42-1008 SHORTWAVE BAND SILENT - by davidff - 01-02-2014, 10:21 AM
RE: 42-1008 SHORTWAVE BAND SILENT - by BrendaAnnD - 01-02-2014, 11:00 AM
RE: 42-1008 SHORTWAVE BAND SILENT - by Eric T - 01-05-2014, 03:49 PM
RE: 42-1008 SHORTWAVE BAND SILENT - by davidff - 01-06-2014, 09:59 AM
RE: 42-1008 SHORTWAVE BAND SILENT - by Eric T - 01-08-2014, 08:36 PM
RE: 42-1008 SHORTWAVE BAND SILENT - by morzh - 01-08-2014, 08:42 PM
RE: 42-1008 SHORTWAVE BAND SILENT - by morzh - 01-08-2014, 08:53 PM
RE: 42-1008 SHORTWAVE BAND SILENT - by Eric T - 01-10-2014, 07:52 PM
RE: 42-1008 SHORTWAVE BAND SILENT - by Jamie - 01-11-2014, 10:59 AM
RE: 42-1008 SHORTWAVE BAND SILENT - by morzh - 01-11-2014, 11:32 AM
RE: 42-1008 SHORTWAVE BAND SILENT - by davidff - 01-12-2014, 03:07 PM
RE: 42-1008 SHORTWAVE BAND SILENT - by morzh - 01-12-2014, 06:11 PM
RE: 42-1008 SHORTWAVE BAND SILENT - by codefox1 - 01-14-2014, 03:18 PM
RE: 42-1008 SHORTWAVE BAND SILENT - by davidff - 01-15-2014, 09:14 AM
RE: 42-1008 SHORTWAVE BAND SILENT - by morzh - 01-15-2014, 09:45 AM
RE: 42-1008 SHORTWAVE BAND SILENT - by hsusmann - 01-15-2014, 01:52 PM
RE: 42-1008 SHORTWAVE BAND SILENT - by morzh - 01-15-2014, 02:30 PM
RE: 42-1008 SHORTWAVE BAND SILENT - by morzh - 01-15-2014, 03:40 PM
RE: 42-1008 SHORTWAVE BAND SILENT - by hsusmann - 01-15-2014, 04:19 PM
RE: 42-1008 SHORTWAVE BAND SILENT - by morzh - 01-15-2014, 04:41 PM
RE: 42-1008 SHORTWAVE BAND SILENT - by Eric T - 01-18-2014, 01:21 AM
RE: 42-1008 SHORTWAVE BAND SILENT - by BrendaAnnD - 01-18-2014, 03:09 AM
Philco 91 Tuning Condenser
There are currently 10209 online users. [Complete List]
» 3 Member(s) | 10206 Guest(s)
