Any restorers in SE Texas?
Gary:
Thanks for your input! The are some cracks in the veneer (on the top), which I'm not quite sure how to fix. I'm reading up on the restoration process, so I'm open to all suggestions. At some point, I'll have to post questions to the refinishing forum, I guess.
Any restorers in SE Texas? - by Guest - 05-18-2008, 04:31 AM
[No subject] - by Guest - 05-18-2008, 10:06 PM
[No subject] - by Guest - 05-19-2008, 12:16 AM
PM - by Guest - 05-19-2008, 09:27 AM
[No subject] - by Guest - 05-19-2008, 03:30 PM
[No subject] - by gary rabbitt - 05-19-2008, 11:08 PM
[No subject] - by Guest - 05-20-2008, 12:41 PM
