370 Chairside Back to Life
Finished my first radio. Its a 370 Chairside that I picked up for $35 earlier in the year. Went through the chassis replaced all the paper caps and electrolytics along with one mica and all but one resistor. Couldn't figure out why I couldn't get any stations until I discovered that a previous repair at some point in it's life rendered it inoperable. Cathode of the oscillator was not wired back to the B.C. Resistor.
370 Chairside Back to Life - by RoyG - 12-30-2013, 02:17 PM
RE: 370 Chairside Back to Life - by Radioroslyn - 12-30-2013, 08:33 PM
RE: 370 Chairside Back to Life - by VntgRads - 12-30-2013, 10:59 PM
RE: 370 Chairside Back to Life - by klondike98 - 12-30-2013, 11:16 PM
RE: 370 Chairside Back to Life - by wireless - 12-31-2013, 05:36 PM
RE: 370 Chairside Back to Life - by TA Forbes - 12-31-2013, 11:22 PM
RE: 370 Chairside Back to Life - by jontz - 01-01-2014, 11:18 AM
RE: 370 Chairside Back to Life - by RoyG - 01-02-2014, 03:49 PM
RE: 370 Chairside Back to Life - by Radioroslyn - 01-02-2014, 05:10 PM
RE: 370 Chairside Back to Life - by RoyG - 01-03-2014, 03:42 AM
RE: 370 Chairside Back to Life - by morzh - 01-03-2014, 09:15 PM
RE: 370 Chairside Back to Life - by PhilcoJohn - 01-06-2014, 07:40 PM
RE: 370 Chairside Back to Life - by Radioroslyn - 01-06-2014, 11:22 PM
Philco 91 Tuning Condenser
