Not sure if I have to rewire....
I am new to the forum, as well as old tube radios. If I read the other posts correctly then am I safe in thinking that I DO NOT need to rewire my 38-5x, 46-131, or 48-460 radios due to the fact that they were made outside the time when the rubber insulation was used?
Just checking before I pull my hair out trying to rewire everything.
John
Not sure if I have to rewire.... - by phly guy - 05-20-2008, 03:07 PM
[No subject] - by Ron Ramirez - 05-20-2008, 06:23 PM
[No subject] - by phly guy - 05-21-2008, 12:34 AM
Eico 232 VTVM Schematic
There are currently 8354 online users. [Complete List]
» 2 Member(s) | 8352 Guest(s)
