Help: Philco-Ford Console Stereo
Hello I am new to this forum and to Philco/Philco-Ford in general.
I recently acquired a Philco-Ford solid state stereo console and I have been restoring it. I will include a bunch of pictures at the end of this post.
Question 1: I have no idea what kind of stereo it is - does anyone know the model?
Question 2: Everything appears to work. But I think I am missing the needle for the turntable (I have no idea). I have never used a turntable before (I am just 24). Does anyone know where I can get a replacement needle and how to install it?
Thank you for any help,
Seth
[Image: https://scontent-a-iad.xx.fbcdn.net/hpho...4121_n.jpg]
[Image: https://scontent-a-iad.xx.fbcdn.net/hpho...4130_n.jpg]
[Image: https://fbcdn-sphotos-d-a.akamaihd.net/h...1377_n.jpg]
[Image: https://scontent-a-iad.xx.fbcdn.net/hpho...1529_n.jpg]
[Image: https://scontent-a-iad.xx.fbcdn.net/hpho...8314_n.jpg]
[Image: https://scontent-b-iad.xx.fbcdn.net/hpho...4739_n.jpg]
[Image: https://scontent-b-iad.xx.fbcdn.net/hpho...1747_n.jpg]
[Image: https://scontent-b-iad.xx.fbcdn.net/hpho...2977_n.jpg]
Help: Philco-Ford Console Stereo - by Eclipsin1 - 12-30-2013, 06:36 PM
RE: Help: Philco-Ford Console Stereo - by morzh - 01-04-2014, 10:17 PM
RE: Help: Philco-Ford Console Stereo - by morzh - 01-04-2014, 10:41 PM
There are currently 9753 online users. [Complete List]
» 1 Member(s) | 9752 Guest(s)
