1920's "C" battery
If the B+ is less than 70 volts or so, you can run 01As with no C bias.
1920's "C" battery - by tab10672 - 12-30-2013, 02:17 AM
RE: 1920's "C" battery - by BrendaAnnD - 12-30-2013, 04:04 AM
RE: 1920's "C" battery - by keithw - 12-30-2013, 09:27 AM
RE: 1920's "C" battery - by TA Forbes - 12-30-2013, 11:39 AM
RE: 1920's "C" battery - by tab10672 - 12-30-2013, 04:49 PM
RE: 1920's "C" battery - by Alan Douglas - 12-30-2013, 10:00 PM
There are currently 6999 online users. [Complete List]
» 1 Member(s) | 6998 Guest(s)
