Model 645 BC Resistor - Which end is C-?
On your radio the BC resistor does not have any positive B+ voltage applied, so your voltage measurements are correct.
The -18 v terminal is the C- end and is where the capacitor should be connected.
RE: Model 645 BC Resistor - Which end is C-? - by Mondial - 12-31-2013, 05:37 PM
Philco 91 Tuning Condenser
