Just received a 650B.....pics
Well, aligned her up tonight. While the dial calibration was on, that's all that can be said. The IFs were way out, tuned somewhere around 451/2 kc. Also the primary IF was off from the secondary IF. I suspected this as the selectivity wasn't quite up to my other two 650s. But fidelity was better.....An added plus I guess. After aligning the IFs, selectivity increased as did over all sensitivity, but lost some fidelity.
The 1st IF secondary adjustment was goofy, I didn't like it. This calls for disassembling that IF to see what's up. Anyhow, as usual the dial calibration came almost spot on. I mean within a hair of accuracy. It amazes me how accurate these sets are on the dial. Anyone that knows me, knows I'm an anal prick when it comes to dial calibration Icon_rolleyes Another added plus is the shadow meter is now more responsive.
Last, I mentioned the tuner assembly was sloppy. Trying to fine tune a station was a lesson in futility. The tuner gang moved, but not the dial. The dial disk mount was tight, though I could hold it lightly, and keep it from moving while tunning. The set screw was tight, so I just loosened it, and moved the disk out a fraction of a hair. Problem solved. Plus the dial scale no longer rubs the diffuser hard. Now you can fine tune to your hearts content.
Well, for you gents who are looking for a nice example, might I recommend one of the 36 models. My reasons are this. Easier to service than the 37 series with their RF sub-chassis. Hot performers right down to the 620, they have that great "30s" look. What else can I say Icon_lol
Here are a few pics of the xfmr work
[Image: http://antiqueradios.com/gallery/d/77716-1/xfmr2.JPG]
[Image: http://antiqueradios.com/gallery/d/77714-1/xfmr1.JPG]
-Brian
If you collect or are interested in antique telephones, please visit Classic Rotary Phones
http://www.classicrotaryphones.com/forum/index.php
Just received a 650B.....pics - by BDM - 05-17-2008, 12:52 PM
[No subject] - by signaltracer - 05-17-2008, 08:33 PM
[No subject] - by BDM - 05-17-2008, 09:36 PM
[No subject] - by BDM - 05-18-2008, 09:31 PM
[No subject] - by signaltracer - 05-18-2008, 09:52 PM
[No subject] - by BDM - 05-18-2008, 10:13 PM
[No subject] - by exray - 05-18-2008, 10:17 PM
[No subject] - by BDM - 05-18-2008, 10:24 PM
[No subject] - by BDM - 05-19-2008, 12:41 AM
[No subject] - by signaltracer - 05-19-2008, 12:02 PM
[No subject] - by Ron Ramirez - 05-19-2008, 06:42 PM
[No subject] - by BDM - 05-19-2008, 08:19 PM
[No subject] - by BDM - 05-20-2008, 10:12 PM
Philco 91 Tuning Condenser
There are currently 8979 online users. [Complete List]
» 2 Member(s) | 8977 Guest(s)
