Model 645 BC Resistor - Which end is C-?
Thanks so much for clarifying that. I spent a few hours retracing the wiring and came up with one error--the 8 mfd and 12 mfd caps were reversed (not the polarity, just their positions in the circuit)--and switching those seems to have improved the audio and possibly the reception.
RE: Model 645 BC Resistor - Which end is C-? - by Winky Dink - 12-31-2013, 08:46 PM
Philco 91 Tuning Condenser
