  • 1 Vote(s) - 5 Average
Philco 91 Code 126
So I worked on the 91 some more last night...
36 tube tests OK...replaced it with another from a working radio anyway...still no dice.
I did find that the primary of the antenna coil was open. Fixed that (a simple matter of a broken wire). Still doesn't work.
I can pass an IF signal through the set just fine now. I did a quick and dirty IF alignment, by ear. Will go back and realign it - the right way, with my oscilloscope - once it's up and running.
I decided not to bother with it tonight. Perhaps tomorrow. I will definitely have to revisit the oscillator coil. And I am still thinking about just converting it to use a 6A7...
Philco 91 Code 126 - by Ron Ramirez - 12-29-2013, 09:20 PM
RE: Philco 91 Code 126 - by morzh - 12-29-2013, 09:36 PM
RE: Philco 91 Code 126 - by Ron Ramirez - 12-29-2013, 09:38 PM
RE: Philco 91 Code 126 - by 37silverstreak - 12-29-2013, 09:43 PM
RE: Philco 91 Code 126 - by murf - 12-29-2013, 09:44 PM
RE: Philco 91 Code 126 - by morzh - 12-29-2013, 09:47 PM
RE: Philco 91 Code 126 - by tab10672 - 12-30-2013, 03:08 AM
RE: Philco 91 Code 126 - by TA Forbes - 12-30-2013, 11:31 AM
RE: Philco 91 Code 126 - by Ron Ramirez - 12-30-2013, 12:52 PM
RE: Philco 91 Code 126 - by Ron Ramirez - 12-31-2013, 11:34 PM
RE: Philco 91 Code 126 - by morzh - 01-01-2014, 12:38 PM
RE: Philco 91 Code 126 - by TA Forbes - 01-01-2014, 02:41 PM
RE: Philco 91 Code 126 - by Mondial - 01-01-2014, 06:05 PM
RE: Philco 91 Code 126 - by Ron Ramirez - 01-01-2014, 06:51 PM
RE: Philco 91 Code 126 - by Mondial - 01-01-2014, 07:20 PM
RE: Philco 91 Code 126 - by Ron Ramirez - 01-01-2014, 09:36 PM
RE: Philco 91 Code 126 - by Ron Ramirez - 01-03-2014, 10:41 PM
RE: Philco 91 Code 126 - by Ron Ramirez - 01-04-2014, 11:38 PM
RE: Philco 91 Code 126 - by klondike98 - 01-05-2014, 10:28 AM
RE: Philco 91 Code 126 - by Ron Ramirez - 01-05-2014, 11:12 AM
RE: Philco 91 Code 126 - by w4rtc - 01-05-2014, 12:12 PM
RE: Philco 91 Code 126 - by Ron Ramirez - 01-05-2014, 01:42 PM
RE: Philco 91 Code 126 - by vinzer - 01-05-2014, 01:56 PM
RE: Philco 91 Code 126 - by morzh - 01-05-2014, 06:33 PM
RE: Philco 91 Code 126 - by TA Forbes - 01-06-2014, 02:33 PM
RE: Philco 91 Code 126 - by Ron Ramirez - 01-06-2014, 05:00 PM
RE: Philco 91 Code 126 - by 37silverstreak - 01-06-2014, 07:42 PM
RE: Philco 91 Code 126 - by morzh - 01-06-2014, 07:50 PM
RE: Philco 91 Code 126 - by LASJayhawk - 01-07-2014, 02:17 PM
RE: Philco 91 Code 126 - by Ron Ramirez - 01-07-2014, 08:12 PM
RE: Philco 91 Code 126 - by Ron Ramirez - 01-07-2014, 08:13 PM
Philco 91 Tuning Condenser
There are currently 10131 online users. [Complete List]
» 2 Member(s) | 10129 Guest(s)
