Philco Shadow Meter Screen
I think anything matte diffusing from any plastic families that lends itself to cutting.
In fact the FR4 laminate for PCBs with green soldermask if thin enough (usuallty a standard board of 2-4 layers is 62 mils thick) will do. Unless you need to bend it. Just make sure enough light comes through. Any used old PCB like a junk controller from old PCs will do.
Philco Shadow Meter Screen - by cwirth - 01-02-2014, 11:00 AM
RE: Philco Shadow Meter Screen - by morzh - 01-02-2014, 02:46 PM
