509X-anyone have one with pictures ?
A quick bing search indicates there are at least 3 or 4 of these with photos on the net. Differences are seen in the grill cloth area. I have visited many private collections in the past 10 years and none I have toured had one of these. 500 produced so if 10% survived that should be 50 or so surviving. Did Philco make the low volumn cabinet or was it perhaps farmed out ?
$600 was a princely sum the year these were made.
RE: 509X-anyone have one with pictures ? - by y2kbruce - 01-02-2014, 05:09 PM
There are currently 9724 online users. [Complete List]
» 1 Member(s) | 9723 Guest(s)
