Help ID parts Canadian Model 91H
as stated in the title i have a model 91H canadian, or from what i can tell... Is there any difference in the US/ Can models? one page I came across would not give info to people asking about canadian models... whats with that?
[Image: https://dl.dropboxusercontent.com/u/1920....10.57.jpg]
From what i can tell its a 1932 model 91 highboy, with model 91 tuner with twin speakers.
I cannot find a part numbers for the twin speakers, there is a 11" and a 7" wired together with a 5 wire plug. they are ruined.
[Image: https://dl.dropboxusercontent.com/u/1920....56.31.jpg]
[Image: https://dl.dropboxusercontent.com/u/1920....56.36.jpg]
[Image: https://dl.dropboxusercontent.com/u/1920....57.03.jpg]
[Image: https://dl.dropboxusercontent.com/u/1920....57.29.jpg]
SEPT 30 1932
Heres some other pics..
The good... it lights up. nice cabinet.. er.. 75% needs work
[Image: https://dl.dropboxusercontent.com/u/1920....54.28.jpg]
[Image: https://dl.dropboxusercontent.com/u/1920....54.15.jpg]
[Image: https://dl.dropboxusercontent.com/u/1920....11.13.jpg]
The Bad... No nobs, speaker mesh, dial face, speakers
[Image: https://dl.dropboxusercontent.com/u/1920....53.50.jpg]
[Image: https://dl.dropboxusercontent.com/u/1920....55.48.jpg]
[Image: https://dl.dropboxusercontent.com/u/1920....55.36.jpg]
Wondering if it is worth fixing up to restored condition, or if i should just use the nice cabinet for a custom PC case.
Help ID parts Canadian Model 91H - by TRusselo - 01-02-2014, 11:21 PM
RE: Help ID parts Canadian Model 91H - by morzh - 01-05-2014, 07:20 PM
RE: Help ID parts Canadian Model 91H - by Arran - 01-06-2014, 01:57 AM
There are currently 9709 online users. [Complete List]
» 1 Member(s) | 9708 Guest(s)
