Rescuing a Philco... but which one? [With many pictures!]
Hello kevin,
Welcome from fellow collector in the Pacific Northwest. I agree with rest group that your set will be nice when done. Please take your time and double check your work before replying power when replacing parts make lot of nots and even take some digital photos were you can.
sincerely Radio Rich
P.S. welcome to the world of Antique radios where nothing is taken lightly Icon_smile
[No subject] - by exray - 05-18-2008, 05:11 PM
[No subject] - by exray - 05-18-2008, 05:30 PM
[No subject] - by Guest - 05-18-2008, 06:07 PM
[No subject] - by exray - 05-18-2008, 08:42 PM
[No subject] - by Guest - 05-18-2008, 10:32 PM
[No subject] - by exray - 05-18-2008, 11:16 PM
[No subject] - by gary rabbitt - 05-19-2008, 11:27 PM
[No subject] - by Guest - 05-21-2008, 10:30 PM
[No subject] - by radiorich - 05-22-2008, 01:37 AM
[No subject] - by Guest - 07-01-2008, 11:13 PM
