Shadow Meter wiring
Make sure the wires in the socket are not shorted. Old sockets often have cracked and crumbling central contact insulator.
Also before you go to the trouble of screwing it back etc it makes sense to check it for being functional. You have already got the link to Chuck's site where there is info about shadographs.
Shadow Meter wiring - by dbrambert - 01-01-2014, 11:34 PM
RE: Shadow Meter wiring - by Steve Chambers - 01-02-2014, 07:23 PM
RE: Shadow Meter wiring - by morzh - 01-02-2014, 08:25 PM
RE: Shadow Meter wiring - by dbrambert - 01-02-2014, 10:53 PM
RE: Shadow Meter wiring - by klondike98 - 01-02-2014, 11:11 PM
RE: Shadow Meter wiring - by morzh - 01-02-2014, 11:14 PM
RE: Shadow Meter wiring - by dbrambert - 01-02-2014, 11:58 PM
RE: Shadow Meter wiring - by morzh - 01-03-2014, 12:35 AM
RE: Shadow Meter wiring - by klondike98 - 01-03-2014, 09:40 PM
RE: Shadow Meter wiring - by dbrambert - 01-11-2014, 09:30 PM
RE: Shadow Meter wiring - by dbrambert - 01-11-2014, 09:31 PM
RE: Shadow Meter wiring - by morzh - 01-11-2014, 09:52 PM
RE: Shadow Meter wiring - by Warren - 01-12-2014, 01:25 AM
RE: Shadow Meter wiring - by BrendaAnnD - 01-12-2014, 02:08 AM
RE: Shadow Meter wiring - by Ron Ramirez - 01-12-2014, 08:58 AM
RE: Shadow Meter wiring - by dbrambert - 01-12-2014, 12:51 PM
RE: Shadow Meter wiring - by Ron Ramirez - 01-12-2014, 04:13 PM
RE: Shadow Meter wiring - by dbrambert - 01-12-2014, 07:55 PM
There are currently 10290 online users. [Complete List]
» 2 Member(s) | 10288 Guest(s)
