resistors coding
This may be helpful in decoding the early resistors.
http://www.philcoradio.com/tech/resistor.htm
resistors coding - by fields 100 - 01-03-2014, 12:34 AM
RE: resistors coding - by Mondial - 01-03-2014, 01:01 AM
RE: resistors coding - by Bradley Rush - 01-04-2014, 06:29 PM
Philco 91 Tuning Condenser
There are currently 10421 online users. [Complete List]
» 2 Member(s) | 10419 Guest(s)
