  • 2 Vote(s) - 5 Average
Philco model 18 (code 121) - HELP!
I am having trouble locating the schematic for this radio.
Someone said it was at post #108 but I did not find it
there either.
If you can tell me how to get to the schematic I would be
happy to look it over for you.
Herb S.
RE: Philco model 18 (code 121) - HELP! - by morzh - 02-07-2013, 10:22 PM
RE: Philco model 18 (code 121) - HELP! - by morzh - 02-08-2013, 10:32 PM
RE: Philco model 18 (code 121) - HELP! - by Arran - 02-08-2013, 10:49 PM
RE: Philco model 18 (code 121) - HELP! - by morzh - 02-09-2013, 02:21 PM
RE: Philco model 18 (code 121) - HELP! - by morzh - 02-09-2013, 05:57 PM
RE: Philco model 18 (code 121) - HELP! - by morzh - 02-09-2013, 06:12 PM
RE: Philco model 18 (code 121) - HELP! - by morzh - 02-13-2013, 08:40 PM
RE: Philco model 18 (code 121) - HELP! - by morzh - 02-21-2013, 05:25 PM
RE: Philco model 18 (code 121) - HELP! - by morzh - 02-28-2013, 06:04 PM
RE: Philco model 18 (code 121) - HELP! - by morzh - 03-07-2013, 04:16 PM
RE: Philco model 18 (code 121) - HELP! - by morzh - 03-07-2013, 11:20 PM
RE: Philco model 18 (code 121) - HELP! - by morzh - 04-17-2013, 01:25 PM
RE: Philco model 18 (code 121) - HELP! - by morzh - 04-18-2013, 08:48 PM
RE: Philco model 18 (code 121) - HELP! - by morzh - 04-18-2013, 09:49 PM
RE: Philco model 18 (code 121) - HELP! - by morzh - 04-29-2013, 10:02 PM
RE: Philco model 18 (code 121) - HELP! - by morzh - 06-12-2013, 01:37 PM
RE: Philco model 18 (code 121) - HELP! - by morzh - 06-13-2013, 08:33 PM
RE: Philco model 18 (code 121) - HELP! - by morzh - 07-23-2013, 10:33 PM
RE: Philco model 18 (code 121) - HELP! - by morzh - 07-24-2013, 11:11 PM
RE: Philco model 18 (code 121) - HELP! - by morzh - 08-02-2013, 05:06 PM
RE: Philco model 18 (code 121) - HELP! - by morzh - 08-21-2013, 10:26 AM
RE: Philco model 18 (code 121) - HELP! - by morzh - 12-17-2013, 10:58 AM
RE: Philco model 18 (code 121) - HELP! - by morzh - 12-19-2013, 12:47 PM
RE: Philco model 18 (code 121) - HELP! - by morzh - 12-19-2013, 08:48 PM
RE: Philco model 18 (code 121) - HELP! - by hsusmann - 01-03-2014, 03:33 PM
RE: Philco model 18 (code 121) - HELP! - by morzh - 01-17-2014, 04:05 PM
Users browsing this thread: 40 Guest(s)
Philco 91 Tuning Condenser
There are currently 9394 online users. [Complete List]
» 1 Member(s) | 9393 Guest(s)
