How to strip a Hippo?
So basicly any commercial paint stripper should work then? I'm not trying to be dense about it. I just don't want to watch it turn into a puddle of goo before my eyes.
Do you recommend/have experience with any particular stripper? I'm just looking to narrow down the field a bit.
Thanks
How to strip a Hippo? - by phly guy - 05-21-2008, 01:42 AM
[No subject] - by batterymaker - 05-22-2008, 08:42 AM
[No subject] - by phly guy - 05-22-2008, 09:01 AM
[No subject] - by Don Lind - 05-22-2008, 11:24 AM
[No subject] - by phly guy - 05-22-2008, 01:42 PM
[No subject] - by Texasrocker - 05-28-2008, 03:13 AM
[No subject] - by batterymaker - 05-30-2008, 08:14 AM
[No subject] - by englishradioman - 07-18-2008, 07:42 PM
[No subject] - by Guest - 07-22-2008, 10:06 PM
[No subject] - by gary rabbitt - 07-23-2008, 12:27 AM
[No subject] - by phly guy - 07-25-2008, 09:15 AM
There are currently 10052 online users. [Complete List]
» 1 Member(s) | 10051 Guest(s)
