Need a clean schematic for Philco 42-380
Chuck Schwark has the best there is. He only deals through the mail, and doesn't do PayPal, but his work is great. Nice big, clear schematics and they come with all service literature and updates.
RE: Need a clean schematic for Philco 42-380 - by BrendaAnnD - 01-03-2014, 05:54 PM
There are currently 8174 online users. [Complete List]
» 1 Member(s) | 8173 Guest(s)
