Philco 20 speaker fiedl coil removal procedure needed
Mike,
Read this it will ease your pain!!!
http://philcoradio.com/phorum/showthread...oil+rewind
RE: Philco 20 speaker fiedl coil removal procedure needed - by Radioroslyn - 01-03-2014, 09:12 PM
Philco 91 Tuning Condenser
There are currently 10490 online users. [Complete List]
» 2 Member(s) | 10488 Guest(s)
