Model 38-5x with a shadow meter?
I'm still a few weeks away from recieving my newly purchased 38-5x and was wondering from the pictures if it indeed has a shadow meter. Can anyone help with the diagnosis? I don't know what they came with or are supposed to have.
[Image: http://i10.photobucket.com/albums/a105/j...co38-5.jpg]
[Image: http://i10.photobucket.com/albums/a105/j...eb9d_3.jpg]
Thanks
Model 38-5x with a shadow meter? - by phly guy - 05-23-2008, 04:55 PM
[No subject] - by Ron Ramirez - 05-23-2008, 07:18 PM
[No subject] - by phly guy - 05-23-2008, 09:55 PM
[No subject] - by Ron Ramirez - 05-23-2008, 11:02 PM
Philco 91 Tuning Condenser
There are currently 10105 online users. [Complete List]
» 2 Member(s) | 10103 Guest(s)
