Early Philco 16 chassis with 5 bands/dual drive??
It's not strictly kosher, but one does have to grudgingly admire the work. Maybe the guy simply couldn't get the original tuning setup, and did what he could to get the radio back into service? It's rather clever, actually. What would you say that mech came from? Maybe one of the 600 series?
RE: Early Philco 16 chassis with 5 bands/dual drive?? - by BrendaAnnD - 01-04-2014, 05:10 AM
There are currently 8698 online users. [Complete List]
» 2 Member(s) | 8696 Guest(s)
