Philco38_15 Thin Cloth wire
What would be the correct size for the cloth wire to go thru the tube socket holes? Anyone have an Idea where I can get any?
Philco38_15 Thin Cloth wire - by Bradley Rush - 01-04-2014, 05:34 AM
RE: Philco38_15 Thin Cloth wire - by Radioroslyn - 01-04-2014, 07:30 PM
RE: Philco38_15 Thin Cloth wire - by klondike98 - 01-04-2014, 07:45 PM
Philco 91 Tuning Condenser
There are currently 9139 online users. [Complete List]
» 1 Member(s) | 9138 Guest(s)
