Details about VARISTOR placement
Just would like to know how anyone would have any Details about putting VARISTOR into a radio. Is there a way to put one so your filaments come up before everything else? I have not seen a schematic showing where they should be placed. ie before the fuse after the switch etc?
Details about VARISTOR placement - by Bradley Rush - 01-04-2014, 12:09 PM
RE: Details about VARISTOR placement - by morzh - 01-04-2014, 12:56 PM
RE: Details about VARISTOR placement - by morzh - 01-04-2014, 02:35 PM
RE: Details about VARISTOR placement - by morzh - 01-04-2014, 03:58 PM
RE: Details about VARISTOR placement - by morzh - 01-04-2014, 04:37 PM
RE: Details about VARISTOR placement - by morzh - 01-04-2014, 04:45 PM
Eico 232 VTVM Schematic
There are currently 9081 online users. [Complete List]
» 1 Member(s) | 9080 Guest(s)
