Details about VARISTOR placement
Yes I was answering your last post. Trying to text it a lil better.
I get that the tube will not conduct til filaments are good and going.
So our saying the Varistors just protect and dont limit.
It is possible where i am at that someone could plug one of my radio's into a 220vac outlet
So if there was a way to use Varistors to make my RADIO beter too wanted to kill two birds with one ohm
RE: Details about VARISTOR placement - by morzh - 01-04-2014, 12:56 PM
RE: Details about VARISTOR placement - by morzh - 01-04-2014, 02:35 PM
RE: Details about VARISTOR placement - by morzh - 01-04-2014, 03:58 PM
RE: Details about VARISTOR placement - by Bradley Rush - 01-04-2014, 04:24 PM
RE: Details about VARISTOR placement - by morzh - 01-04-2014, 04:37 PM
RE: Details about VARISTOR placement - by morzh - 01-04-2014, 04:45 PM
Philco 91 Tuning Condenser
There are currently 8830 online users. [Complete List]
» 2 Member(s) | 8828 Guest(s)
