Philco38_15 Thin Cloth wire
Is this what you are looking for?
http://www.sundialwire.com/clothcoveredwire.aspx or http://www.radiodaze.com/category/400.aspx
Philco38_15 Thin Cloth wire - by Bradley Rush - 01-04-2014, 05:34 AM
RE: Philco38_15 Thin Cloth wire - by Radioroslyn - 01-04-2014, 07:30 PM
RE: Philco38_15 Thin Cloth wire - by klondike98 - 01-04-2014, 07:45 PM
Philco 91 Tuning Condenser
There are currently 6868 online users. [Complete List]
» 2 Member(s) | 6866 Guest(s)
