Cleaning and Polishing Bakelite knobs
I first clean them with purple power (best cleaner I have ever used) then I buff with cheap walmart rubbing compound and a dremel "cloth" cleaning wheel not the fiber wheels. They look like they are coated with wet oil after washing the dry compound off. This also works for scuffed/scratched and yellow plastic dial glass. Todd
RE: Cleaning and Polishing Bakelite knobs - by tab10672 - 01-04-2014, 08:59 PM
Philco 91 Tuning Condenser
There are currently 9583 online users. [Complete List]
» 2 Member(s) | 9581 Guest(s)
