650B tone control values
Guys, I want to replace the caps inside my tone control. The part number from the schematic is a #30-4343. I don't see this one listed on Chucks site. I assume points 1 2 3 & 4 are as follows. 1 = open, point 2 is the first position back to the cap and so on for points 3 & 4? Thanks.
-Brian
If you collect or are interested in antique telephones, please visit Classic Rotary Phones
http://www.classicrotaryphones.com/forum/index.php
650B tone control values - by BDM - 05-25-2008, 12:37 AM
[No subject] - by BDM - 05-25-2008, 12:42 AM
[No subject] - by Ron Ramirez - 05-25-2008, 12:01 PM
[No subject] - by BDM - 05-25-2008, 12:26 PM
[No subject] - by BDM - 05-25-2008, 04:40 PM
Philco 91 Tuning Condenser
