650B tone control values
I found it listed in the schematic as .01 .003 and .01 in that order. All listed under part #57. Am I correct?
http://www.nostalgiaair.org/PagesByModel...013824.pdf
-Brian
If you collect or are interested in antique telephones, please visit Classic Rotary Phones
http://www.classicrotaryphones.com/forum/index.php
650B tone control values - by BDM - 05-25-2008, 12:37 AM
[No subject] - by BDM - 05-25-2008, 12:42 AM
[No subject] - by Ron Ramirez - 05-25-2008, 12:01 PM
[No subject] - by BDM - 05-25-2008, 12:26 PM
[No subject] - by BDM - 05-25-2008, 04:40 PM
Philco 91 Tuning Condenser
