Putzing around with 90's detector.
It would require a lot of circuit redesign to use a 1N34 in this particular style of detector. However, if you feel up to it, you could experiment with the plate and cathode resistors' values to alter the curve on the detector.
Putzing around with 90's detector. - by morzh - 01-04-2014, 10:32 PM
RE: Putzing around with 90's detector. - by morzh - 01-05-2014, 12:07 AM
RE: Putzing around with 90's detector. - by BrendaAnnD - 01-05-2014, 12:16 AM
RE: Putzing around with 90's detector. - by morzh - 01-05-2014, 12:55 AM
RE: Putzing around with 90's detector. - by morzh - 01-15-2014, 11:02 PM
Philco 91 Tuning Condenser
There are currently 10080 online users. [Complete List]
» 1 Member(s) | 10079 Guest(s)
