39-7: The Saga continues
Well.....
Tonight, I finished applying the veneer. Let's put it this way, the first 3/4 of the application didn't go too badly. On the other hand, the last curve and side.. not so much. I used a bit too much glue, and as a result there is some waviness on the side. Fortunately, it doesn't show much from the front.
Mistakes were made:
While cutting the holes for the knobs, buttons and dial escutcheon, I made a bit of a mess of things, as you can see from the above pic. I'm going to try to clean them up a bit. I also erred by installing the escutcheon upside down. That's a PITA one to redo, as it has clips that one must manipulate underneath some tabs. I still have one more slot in the speaker grill to cut out.
This has all been a first attempt at doing a fairly (at least to me it is) complex veneer repair. And that was after fixing all the cabinet problems like separated joints and the "backbones" for the curved corners. I guess all in all, it's not TERRIBLE, just not quite what I had envisioned. Tomorrow, I'll cut out that last slot, clean up the divots, fix the escutcheon and stain the cabinet. I'll post another pic after that's done.
39-7: The Saga continues - by BrendaAnnD - 01-03-2014, 12:10 PM
RE: 39-7: The Saga continues - by PhilcoMike - 01-03-2014, 12:43 PM
RE: 39-7: The Saga continues - by morzh - 01-03-2014, 09:12 PM
RE: 39-7: The Saga continues - by BrendaAnnD - 01-04-2014, 10:56 AM
RE: 39-7: The Saga continues - by TA Forbes - 01-04-2014, 11:58 AM
RE: 39-7: The Saga continues - by morzh - 01-04-2014, 04:51 PM
RE: 39-7: The Saga continues - by BrendaAnnD - 01-04-2014, 06:04 PM
RE: 39-7: The Saga continues - by hsusmann - 01-04-2014, 06:42 PM
RE: 39-7: The Saga continues - by morzh - 01-04-2014, 09:12 PM
RE: 39-7: The Saga continues - by BrendaAnnD - 01-04-2014, 11:45 PM
RE: 39-7: The Saga continues - by BrendaAnnD - 01-05-2014, 10:18 AM
RE: 39-7: The Saga continues - by w4rtc - 01-05-2014, 12:31 PM
RE: 39-7: The Saga continues - by morzh - 01-05-2014, 01:02 PM
RE: 39-7: The Saga continues - by hsusmann - 01-05-2014, 02:33 PM
RE: 39-7: The Saga continues - by Warren - 01-05-2014, 02:38 PM
RE: 39-7: The Saga continues - by Joeztech - 01-05-2014, 05:41 PM
RE: 39-7: The Saga continues - by Eric Adams - 01-05-2014, 05:50 PM
RE: 39-7: The Saga continues - by BrendaAnnD - 01-06-2014, 12:07 PM
RE: 39-7: The Saga continues - by BrendaAnnD - 01-06-2014, 12:25 PM
RE: 39-7: The Saga continues - by Joe Rossi - 01-06-2014, 05:35 PM
RE: 39-7: The Saga continues - by Eric Adams - 01-06-2014, 06:50 PM
RE: 39-7: The Saga continues - by hsusmann - 01-06-2014, 06:58 PM
RE: 39-7: The Saga continues - by BrendaAnnD - 01-07-2014, 11:53 AM
RE: 39-7: The Saga continues - by BrendaAnnD - 01-08-2014, 08:52 AM
RE: 39-7: The Saga continues - by morzh - 01-08-2014, 02:38 PM
RE: 39-7: The Saga continues - by BrendaAnnD - 01-08-2014, 03:27 PM
RE: 39-7: The Saga continues - by morzh - 01-08-2014, 04:25 PM
RE: 39-7: The Saga continues - by BrendaAnnD - 01-08-2014, 07:17 PM
RE: 39-7: The Saga continues - by morzh - 01-08-2014, 07:31 PM
RE: 39-7: The Saga continues - by BrendaAnnD - 01-08-2014, 09:12 PM
RE: 39-7: The Saga continues - by TA Forbes - 01-08-2014, 09:24 PM
RE: 39-7: The Saga continues - by BrendaAnnD - 01-08-2014, 10:15 PM
RE: 39-7: The Saga continues - by jontz - 01-09-2014, 07:54 AM
RE: 39-7: The Saga continues - by BrendaAnnD - 01-09-2014, 10:41 AM
Philco 91 Tuning Condenser
There are currently 4803 online users. [Complete List]
» 2 Member(s) | 4801 Guest(s)
