37-610 Voltage measurements
Too high a plate voltage usually points to either a dead tube, or an open or high impedence cathode circuit. Since the cathode on your 6Q7 is tied directly to ground, that almost leaves the tube itself as the culprit. That's the only thing I can see in that schematic.
37-610 Voltage measurements - by Arizona_steve - 01-05-2014, 01:58 AM
RE: 37-610 Voltage measurements - by BrendaAnnD - 01-05-2014, 10:35 AM
RE: 37-610 Voltage measurements - by klondike98 - 01-05-2014, 10:36 AM
RE: 37-610 Voltage measurements - by morzh - 01-12-2014, 12:44 AM
Philco 91 Tuning Condenser
There are currently 10051 online users. [Complete List]
» 2 Member(s) | 10049 Guest(s)
