37-610 Voltage measurements
Welcome to the Phorum! Lots of good folks here to help you out. All the paper caps including those bakelite block caps need to be replaced even if the radio is working now. The bakelites are not that hard to rebuild: see the info here http://www.philcoradio.com/tech/blocks.htm and http://www.philcorepairbench.com/capbuild.htm
37-610 Voltage measurements - by Arizona_steve - 01-05-2014, 01:58 AM
RE: 37-610 Voltage measurements - by BrendaAnnD - 01-05-2014, 10:35 AM
RE: 37-610 Voltage measurements - by klondike98 - 01-05-2014, 10:36 AM
RE: 37-610 Voltage measurements - by morzh - 01-12-2014, 12:44 AM
Philco 91 Tuning Condenser
There are currently 10078 online users. [Complete List]
» 3 Member(s) | 10075 Guest(s)
