Crosley Table top fiver
The dial string is simple on that model. There is a big pulley behind the dial and the tuning shaft is the center shaft. The string runs around the big pulley, then loops around the shaft two or three times. The dial turns in the same direction as the knob, so no need to figure 8 it.
As for cleaning the glass, just clean the front like you would any glass. The back has the graphics, so use a q-tip and be very careful.
Crosley Table top fiver - by wireless - 12-31-2013, 05:42 PM
RE: Crosley Table top fiver - by wireless - 12-31-2013, 05:45 PM
RE: Crosley Table top fiver - by morzh - 12-31-2013, 05:52 PM
RE: Crosley Table top fiver - by wireless - 12-31-2013, 06:43 PM
RE: Crosley Table top fiver - by Radioroslyn - 12-31-2013, 07:30 PM
RE: Crosley Table top fiver - by morzh - 12-31-2013, 08:14 PM
RE: Crosley Table top fiver - by klondike98 - 12-31-2013, 08:15 PM
RE: Crosley Table top fiver - by wireless - 12-31-2013, 08:23 PM
RE: Crosley Table top fiver - by Jayce - 12-31-2013, 10:52 PM
RE: Crosley Table top fiver - by Radioroslyn - 01-01-2014, 11:31 AM
RE: Crosley Table top fiver - by wireless - 01-03-2014, 03:36 PM
RE: Crosley Table top fiver - by Jamie - 01-05-2014, 03:05 PM
RE: Crosley Table top fiver - by wireless - 01-05-2014, 03:46 PM
RE: Crosley Table top fiver - by wireless - 02-09-2014, 12:36 AM
RE: Crosley Table top fiver - by Eliot Ness - 02-11-2014, 10:14 AM
RE: Crosley Table top fiver - by wireless - 03-02-2014, 06:43 PM
RE: Crosley Table top fiver - by morzh - 03-02-2014, 08:33 PM
RE: Crosley Table top fiver - by Jayce - 03-02-2014, 09:10 PM
RE: Crosley Table top fiver - by wireless - 05-12-2014, 11:58 AM
