DIAL STRING 38_15
Assuming that the tuner is in the fully meshed position in your drawing, I would add one turn around the pulley going counterclockwise. The tuning shaft should have at least 2 1/2 turns around it. No turns around the upper shaft, it's just there for tensioning.
YMMV
DIAL STRING 38_15 - by Bradley Rush - 01-05-2014, 04:15 PM
RE: DIAL STRING 38_15 - by BrendaAnnD - 01-05-2014, 04:20 PM
RE: DIAL STRING 38_15 - by Bradley Rush - 01-05-2014, 04:33 PM
Philco 91 Tuning Condenser
There are currently 10485 online users. [Complete List]
» 2 Member(s) | 10483 Guest(s)
