philco model 47-1230 console Need Help
one more question.....does not the center tap divide the voltage readings but I am uncertain at to whether the resistance or ohms reading is halved as well......
RE: philco model 47-1230 console Need Help - by victor3d - 01-05-2014, 04:30 PM
Philco 91 Tuning Condenser
