Scored a 37-116x DeLuxe today
Keith, you are right, the chassis is a monster. I traveled 6 hrs round trip for mine back in the fall. My wife also is terrific to go along with this. My grille cloth is shot too but the speaker is good. Cabinet on mine is good too except for the top which must have held an overwatered plant. I hope to start on it before spring. Enjoy yours
Ron
Philco 37-116.    Philco 70
Philco 52-944.    AK 84
Scored a 37-116x DeLuxe today - by ipwizard - 01-05-2014, 08:00 PM
RE: Scored a 37-116x DeLuxe today - by jontz - 01-05-2014, 08:08 PM
RE: Scored a 37-116x DeLuxe today - by 462ron - 01-05-2014, 08:34 PM
RE: Scored a 37-116x DeLuxe today - by morzh - 01-05-2014, 11:55 PM
RE: Scored a 37-116x DeLuxe today - by TA Forbes - 01-06-2014, 02:27 PM
RE: Scored a 37-116x DeLuxe today - by PhilcoJohn - 01-06-2014, 07:26 PM
Philco 91 Tuning Condenser
There are currently 4009 online users. [Complete List]
» 1 Member(s) | 4008 Guest(s)
