philco model 47-1230 console Need Help
Victor, I do believe your on the right track. I don't think the problem is in the OP transformer. I'm certain you can find a proper pot at Mouser or Mark Oppat.
Regards, Jerry
RE: philco model 47-1230 console Need Help - by jerryhawthorne - 01-05-2014, 10:25 PM
Philco 91 Tuning Condenser
There are currently 2879 online users. [Complete List]
» 1 Member(s) | 2878 Guest(s)
