substitute for a 32-7905N Audio Xformer?
I just posted a WTB on the want ads section but thought I'd ask a related question here too. Can anyone suggest an available, functional substitute for the audio output transformer used in a 38-690 (Philco p/n 32-7905N)? It would not have to be fused as the original is, just suitable for use with the 6L6 push-pull output.
Dave Perkins
Old Radios
Old Volvos
and homebrew beer !
substitute for a 32-7905N Audio Xformer? - by Nadanutcase - 01-05-2014, 11:12 PM
Philco 91 Tuning Condenser
